GigabitEthernet0/3 is down, line protocol is down (err-disabled)
Apr 8th, 2008
We had a 3560 go down today. It had an err-disable on its GigabitEthernet port.
This is a first. Do you guys have any clue as to why it would do this?
The 6513 FastEthernet stated that it was up/up.
I'm scratching my head for now...
Thanks!
mohammedmahmoud Tue, 04/08/2008 - 10:36
  • Green, 3000 points or more
Please post the output of "show interface status err-disabled", it should have the reason, example:
Switch#show interfaces status err-disabled
Port Name Status Reason
Fa0/13 err-disabled bpduguard
BR,
Mohammed Mahmoud.
djgizmo250 Tue, 04/08/2008 - 10:41
I already put the switch online by doing a shut/no shut on the port.
Here's the output of the show interface g0/3.
Hardware is Gigabit Ethernet, address is 0013.1933.ef9b (bia 0013.1933.ef9b)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed
input flow-control is off, output flow-control is off
Last input 00:59:19, output 00:59:19, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
178072502 packets input, 3914189599 bytes, 0 no buffer
Received 129108645 broadcasts (0 multicast)
0 watchdog, 77596408 multicast, 0 pause input
35696681 packets output, 393726150 bytes, 0 underruns
mohammedmahmoud Tue, 04/08/2008 - 10:53
Without the output of "show interfaces status err-disabled" we can't say what was the reason of the err-disable, please issue it if this reoccurs.
BR,
Mohammed Mahmoud.
djgizmo250 Tue, 04/08/2008 - 11:07
Will do. Thanks for the input.
I was in a panic mode and wanted to get the department back online ASAP.
If it occurs again, I'll be sure to issue the "show interfaces status err-disabled".
Thanks again!
mohammedmahmoud Tue, 04/08/2008 - 11:21
You are very welcomed, and good luck.
BR,
Mohammed Mahmoud.
