1250 802.11n wpa tkip compatible?
Answered Question
We just got a 1250 AP and are trying to configure 802.11n on it. We were using WPA(Enterprise) and TKIP and I got the message below:
Apr 8 14:24:12: %DOT11-4-NO_HT: Interface Dot11Radio0, Mcs rates disabled on vlan 132 due to not using AES encryption or encryption is not disabled
Users who connected got only speeds up to 54Mb/s.
I changed the ciphers to use AES-CCM instead of TKIP, the message went away and hosts were able to connect with 802.11n speeds.(m1.,m2.,etc)
The log message makes it seem like you have to use AES, is this the case or do I need to add something to the config?
Joe
Correct Answer by Scott Fella about 9 years 1 month ago
802.11N standard doesn't support WPA-TKIP.... you have to use AES.... Most likey WPA2-AES....
I learned the hard way too.
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Tue, 04/08/2008 - 19:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Stephen Rodriguez Wed, 04/09/2008 - 07:14
  • Purple, 4500 points or more
Correct, 802.11n must be either secured with WPA2/AES OR Open to be able to get the N rates.
rsumpter Wed, 04/09/2008 - 10:20
Can 802.11g & 802.11a clients still connected with WPA (enterprise) and TKIP on a 1250 AP?
Scott Fella Wed, 04/09/2008 - 14:47
  • Hall of Fame,
    2017 Wireless
Yes.... but when you try to enable 40mhz channel width, users will not be able to authenticate. You should start to migrate users to WPA2 if possible.
Trending Topics - Security & Network
