ios recommendations
Apr 8th, 2008
i am running a stack swith with 3750
here is the show version
i need ip multicast routing with sparse dense mode what ios image do i need?
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(44)SE, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 05-Jan-08 00:29 by weiliu
Image text-base: 0x00003000, data-base: 0x01440000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWAR
E (fc)
Switch uptime is 1 day, 12 hours, 16 minutes
System image file is "flash:c3750-ipbasek9-mz.122-44.SE/c3750-ipbasek9-mz.122-44
.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-24PS (PowerPC405) processor (revision D0) with 118784K/12280K by
tes of memory.
Processor board ID FOC1026Y0BJ
Last reset from power-on
4 Virtual Ethernet interfaces
48 FastEthernet interfaces
88 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0A:B8:3D:11:00
Motherboard assembly number : 73-9357-08
Power supply part number : 341-0108-03
Motherboard serial number : FOC10253U7E
Power supply serial number : DCA10231H3K
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3750G-24PS-S
System serial number : FOC1026Y0BJ
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT10201JXP
Top Assembly Part Number : 800-25429-03
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : CNMWL10ARA
Hardware Board Revision Number : 0x05
paolo bevilacqua Tue, 04/08/2008 - 11:02
  • Hall of Fame,
    Founding Member
The advanced image, the only other available.
ggittins Tue, 04/08/2008 - 11:04
if i bought the standard image and i tried to download the advance it did let me
why>
paolo bevilacqua Tue, 04/08/2008 - 11:17
  • Hall of Fame,
    Founding Member
Hi, we like to discuss mainly on technical issues here.
What you can download and can or cannot legally use, it's your responsibility only. Once upon a time, it was called honor system.
You will find however that cisco's stance to protecting licensing is changing, and the latest generation switches (xxx-E)are an example.
ggittins Tue, 04/08/2008 - 11:18
so can i buy the right to get this switch to enhanced mode?
paolo bevilacqua Tue, 04/08/2008 - 12:54
  • Hall of Fame,
    Founding Member
Yes. Your cisco reseller should be able to order the upgrade license for you.
