Troubles configuring T1
matt_drmmer
Hi - I am trying to bring up a new data T1 for us and I seem to be running into some issues. I am trying to connect it to the same router that our ISP hands off a metro ethernet circuit to us but the router just will not take the configuration. The router has 2 WIC's installed but it does not show them in the configuration. I think I might just be missing some really simple setting so hopefully someone here can assist. Here is a snippet of the configuration and information from the router (cleaned), any assistance would be greatly appreciated.
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 02-Feb-02 03:36 by kellythw
Image text-base: 0x80008088, data-base: 0x80989870
ROM: System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
RTR01 uptime is 32 weeks, 1 hour, 35 minutes
System restarted at 12:32:00 MDT Tue Aug 28 2007
System image file is "flash:c2600-i-mz.122-5d.bin"
cisco 2621 (MPC860) processor (revision 0x00) with 28672K/4096K bytes of memory.
Processor board ID JAD06150MM9 (866826577)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
RTR01#conf t
Enter configuration commands, one per line. End with CNTL/Z.
DHQ-MOE-RTR01(config)#controller T1 0/1
% Invalid input detected at '^' marker.
RTR01(config)#controller ?
% Unrecognized command
RTR01(config)#controller T1 ?
RTR01#sh run | be interface
interface FastEthernet0/0
description EDGE-SW01 Fa0/4
ip address ZZZ.ZZZ.ZZZ.ZZZ 255.255.255.0
speed 100
full-duplex
interface Serial0/0
description T1 backup for MoE
ip address XXX.XXX.XXX.XXX 255.255.255.252
service-module t1 timeslots 1-24
no cdp enable
interface FastEthernet0/1
description MoE 3750 IP-XXX.XXX.XXX.XXX
ip address YYY.YYY.YYY.YYY 255.255.255.0
speed 10
full-duplex
interface Serial0/1
shutdown
no cdp enable
9 Replies 9
paolo bevilacqua
What WICs don't show in config? You have two already. Please send output of "show diag" to see what's installed in the router.
Thank you for replying, I am pretty much stumped and at a loss on this. The WIC's do show up but I cannot configure them, when I enter into configure terminal mode on the router and type controller it does not return anything for example;
RTR01#conf t
Here is the output from the show diag command;
RTR01#show diag
Slot 0:
C2621 2FE Mainboard Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 0.0
PCB Serial Number : JAD06150MM9 (866826577)
Part Number : 73-3200-11
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 A2 41 00 00 C1 17 4A 41 44 30 36 31
0x10: 35 30 4D 4D 39 20 28 38 36 36 38 32 36 35 37 37
0x20: 29 82 49 0C 80 0B 04 00 81 00 00 00 00 42 41 30
0x30: 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
FT1 WAN daughter card
Hardware revision 1.3 Board revision C0
Serial number 20189598 Part number 800-03279-03
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
0x20: 02 11 01 03 01 34 11 9E 50 0C CF 03 00 00 00 00
0x30: 60 00 00 00 00 06 25 01 FF FF FF FF FF FF FF FF
WIC Slot 1:
Hardware revision 1.4 Board revision F1
Serial number 25982289 Part number 800-03279-04
0x20: 02 11 01 04 01 8C 75 51 50 0C CF 04 00 00 00 00
0x30: 79 00 00 00 01 09 09 01 FF FF FF FF FF FF FF FF
It just seems strange that I cannot configure the T1 controller on thie router. Thank you once again for any insight.
Matt:
I may be wrong, but I think the 2600 utilizes a 'controller' in its newer T1/E1 Voice WAN Flex WIC cards with IOS Software Release 12.0(5)XK, 12.0(7)T or a later, not the legacy T1 CSU/DSU WIC cards.
Instead of trying to enter controller mode, try going into interface configuration mode and use the following commands to configure the framing, coding and clocking for the T1.
Example:
interface s0/0
and then enter one or more of the following:
-service-module t1 clock source line
-service-module t1 data-coding normal
-service-module t1 timeslots all speed 64
-service-module t1 framing esf
-service-module t1 lbo none
-service-module t1 linecode b8zs
Try reading this link:
http://www.cisco.com/en/US/docs/ios/12_2/12_2z/12_2zl/feature/guide/t1dsu.html#wp1032260
Victor
Matt:
A quick clarification...
After reading my post, I realized that you may misinterpret what I wrote as a recommendation for how to actually configure the interface. It wasn't. I was just trying to show you examples of what kind of configurations can be made from that mode.
I assume you know which features you want configured and what to configure them for. If you need help with that, come back.
So, under interface s0/0, try doing a "service-module t1 ?" to find out all the options that are available to you.
VL
Victor - Thank you very much for the link, I read through it and did a test on my router and the commands work exactly how you described so that must be what is going on. The only thing that I don't quite get is although I can run those commands, when I look at the running configuration after the commands do not appear. This is what it looks like;
RTR01#conf t
RTR01(config)#int S0/0
RTR01(config-if)#service-module ?
t1 T1
RTR01(config-if)#service-module t1 ?
clock Service module clock source
data-coding Service module DCE line coding
fdl Specify the FDL standard for a DS1 data link
framing Framing format
lbo Line Build Out format
linecode Line coding format
remote-alarm-enable Remote/Yellow alarm enable
remote-loopback Remote Loopback/RL disable
timeslots Fraction timeslots
RTR01(config-if)#service-module t1 clock source line
RTR01(config-if)#service-module t1 framing ?
esf ESF format
sf SF format
RTR01(config-if)#service-module t1 framing esf
RTR01(config-if)#service-module t1 linecode b8z
RTR01(config-if)#service-module t1 linecode b8zs
RTR01(config-if)#^Z
RTR01#sh run | be Serial0/0
interface Serial0/0
no cdp enable
description MoE 3750 IP-ZZZ.ZZZ.ZZZ.ZZZ
ip address YYY.YYY.YYY.YYY 255.255.255.252
speed 10
full-duplex
I will need to contact the vendor and see about scheduling a time that we can turn up the T1 to see if perhaps the commands appear when the circuit is live. Thank you again for the help, I really appreciate it.
Hi, commands that doesn't appear are default.
To see how's the T1s are doing, "show service-module serial".
Matt, you're welcome.
Paulo is right, default settings sometimes do not appear in the running configuration.
If you notice in the document, the running configuration shows that the serial interface was configured for SF framing and AMI coding, which are different than what you configured. So, perhaps ESF and B8ZS are the defaults.
Anyway, you can easily verify your configuration by using the show service-module serialX/Y command.
Have a great day.
Victor
Thank you Paulo and Victor, that works like a charm, and as always I have learned a ton. I really appreciate all of the help from you folks.
No sweat, thanks for the nice rating and good luck!
