EIGRP and static routes
Answered Question
Apr 8th, 2008
I currently have a route that is known by EIGRP redistribution.
sh ip route
Routing entry for
Known via "eigrp 65204", distance 170, metric 63232, type external
Redistributing via eigrp 65204
Last update from on GigabitEthernet1/4, 18:25:55 ago
Routing Descriptor Blocks:
*, from, 18:25:55 ago, via GigabitEthernet1/4
Route metric is 63232, traffic share count is 1
Total delay is 210 microseconds, minimum bandwidth is 44247 Kbit
Reliability 254/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
I'd like to add a static route to the same destination using a higher administrative distance.
ip route 220
This is to be used as a backup in case of the other route via EIGRP fails. Would this work?
Correct Answer by Jon Marshall about 8 years 6 months ago
Yes it will work.
Overall Rating: 5 (1 ratings)
