help with rsh command
Apr 8th, 2008
i'm send commands to my router 2600 with rsh from Linux. How can i send commands for configure from Linux? for example: send command that configure terminal > interface FastEthernet0/0 > ..... from linux, because can't send full command.
aghaznavi Mon, 04/14/2008 - 05:49
To enable RSH application inspection or to change the ports to which the security appliance listens, use the inspect rsh command in class configuration mode. Class configuration mode is accessible from policy map configuration mode. To remove the configuration, use the no form of this command.
inspect rsh
no inspect rsh
