04-08-2008 05:06 PM - edited 03-05-2019 10:16 PM
We have a main location with a 3750 we are using as a core switch. We have vlan 2 defined for voip. voip is using dhcp. we have 8 branches, i have defined a vlan 2 in the 2801 router at each location. (connected back to main via mpls vpn) router forwards dhcp requests back to main site. Am I going to run into problems with the same vlan number at branches and main office? especially when data from branch voip vlan 2 will be traversing core switch...
Solved! Go to Solution.
04-08-2008 05:48 PM
No you should be ok there as well as long as you have setup the DHCP scopes on the Server correctly for everyone of those sites. I assume you are using the ip helper-address configuration at the remote site.
04-08-2008 05:16 PM
No, you shouldn't have any problems. Since the sites are separated by layer 3 (MPLS) connection the VLAN # should be transparent between the sites. Think of it as two separate layer 2 domains.
Sundar
04-08-2008 05:27 PM
Each vlan 2 gets an address from a Microsoft DHCP server, even though they have different subnets, would this have any affect on the Microsoft DHCP server to give out addresses?
04-08-2008 05:48 PM
