Outside Calls routed to voice ports
Apr 8th, 2008
Hello i have a cisco voice gateway with two voice port used for cellular access. I have a E1. From inside i have a pattern to access that port and make the call to cellular. But now i want to be able to dial from home and access to that voice port to be able to make call to cellular through my voice gateway, ideas for this?
gogasca Tue, 04/08/2008 - 20:26
If using CCM you can use Mobility Manager which is built in in 6.0
If simple Voice GW create a dial-peer incoming withouth direct-inward-dial and dial from there.
PSTN -- match incoming dial-peer
you will hear dialtone, then dial your number
Configure POTS dial-peer to hairpin the call
