Using AXL tool to Add CTI route points
I am trying to figure out how to use the AXL SQL tool to bulk add CTI route points.
I can see from the AXLSOAP.xsd file that there are options for get/add/update of cti route points available, but cannot figure out the correct XML to do this. as its name suggests can you only do sql statements using this tool? no good at java to write something, maybe pearl, anyone done this before?
Dave Kemp
gogasca Tue, 04/08/2008 - 20:58
Which CCM version?
Not an AXL tool...but have you tried BAT?
Tim Smith Wed, 04/09/2008 - 07:13
Hi Dave,
AXL is definitely not limited to SQL.
I have seen perl examples.. but not a lot of them.
I originally got a C++ request working, after a while, I started mucking around with and found this probably the easiest.
I originally just started by looking at the XML schema docs for AXL and building the requests by hand, and using the traces on the CallManager to tell me what I was doing wrong.
