dongdongliu Wed, 04/09/2008 - 00:34
hi,
I think these are needed:
access-list 100 extended permit tcp any host 50.50.50.50 eq pcanywhere-data
access-list 100 extended permit udp any host 50.50.50.50 eq pcanywhere-status
rechard_david Wed, 04/09/2008 - 03:17
Dear Sir,
I try to tested like this but it doesn't work.
by the way when i change the like this
access-list 100 extended permit tcp any host 50.50.50.51 eq 3389 it working.
Note: Public ip add 50.50.50.51 not the same public ip add on interface e0/0.
I want to use only one public ip add for map and use in the same interface e0/0.
How can i do it? do you have any command for solve this problem?
Best Regards and Thanks,
alanajjar Wed, 04/09/2008 - 04:35
Change your ACL and static nat to the following :
access-list 100 extended permit icmp any inteface outside
access-list 100 extended permit tcp any interface outside eq 5900
access-list 100 extended permit tcp any interface outside eq 3389
for the static nat :
static (inside,ouside) interface 5900 10.10.10.2 5900 netmask 255.255.255.255
static (inside,ouside) interface 3389 10.10.10.2 3389 netmask 255.255.255.255
these commands tell the ASA to use the ip address of the outside interface.
with regards
