Question about Cisco ASA 5520 VPN
jamesgonzo
I have managed to complete phase 1 and phase 2 of the VPN from the ASA 5520 to the remote office which is a Cisco 877 DSL router.
Now here is the difficult part to explain:
Is seems that if I ping servers from the remote office to servers on the inside of the ASA they won't reply, but if I reverse this and I send a ping from one of the servers on the ASA's inside to the remote network it will time-out (on one line) then come up and then both sides can ping. It's as if the ASA/server side can start the communication only which is not right, I want both sides to be able to do this.
I then notice on the ASA 5520 that I will have 1 IKE tunnel and 1 IPSec tunnels, and these IPsec tunnels will increase if I ping from another server to the remote network, is the right?
I pinged the remote network from 4 servers and it went:
1 IKE Tunnel 1 IPSec Tunnel
1 IKE Tunnel 2 IPSec Tunnel
1 IKE Tunnel 3 IPSec Tunnel
1 IKE Tunnel 4 IPSec Tunnel
If I ping from another server not yet used it will be:
1 IKE Tunnel 5 IPSec Tunnel
I thought 1 IEK and 1 IPSec tunnel would support all communication.
11 Replies 11
aansatosorigin
Hi James,
Can you provide us the ASA configuration,or if possible, the router site also.So we can definitely assist you further.
Here is the 877 config, but the ASA's config is so big which parts are just can have posted here, we the crypto part be enough?
Hi James,
Please provide me:
a) NAT - global, inside, outside
b) route - static and default
c) all crypto parts
Here it is:
nat-control
global (outside) 1 interface
nat (outside) 1 192.168.7.0 255.255.255.0
nat (outside) 1 192.168.8.0 255.255.255.0
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0
sysopt noproxyarp inside
sysopt noproxyarp DMZ1_Web_Servers
service resetoutside
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-256-SHA ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 82.149.110.103
crypto map outside_map 1 set transform-set ESP-AES-256-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
tunnel-group 81.x.x.103 type ipsec-l2l
tunnel-group 81.x.x.103 ipsec-attributes
pre-shared-key 123456789
class-map inspection_default
match default-inspection-traffic
route outside 172.19.15.0 255.255.255.0 Internet_Router 1
access-list inside_access_in extended permit ip any 172.19.15.0 255.255.255.0
access-list inside_outbound_nat0_acl extended permit ip any 172.19.15.0 255.255.255.0
You need to have a nat exemption on the outside interface. Add this to your config and it should fix the issue:
access-list inside_outbound_nat0_acl permit ip 192.168.7.0 255.255.255.0 172.19.15.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.8.0 255.255.255.0 172.19.15.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 172.19.15.0 255.255.255.0 192.168.7.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 172.19.15.0 255.255.255.0 192.168.8.0 255.255.255.0
nat (outside) 0 inside_outbound_nat0_acl
What does nat (outside) 0 inside_outbound_nat0_acl do?
Also: 192.168.7.0 and 192.168.8.0 are other VPn networks not internal, my internal lAN is 192.168.21.0 and 192.168.20.0 should these be added?
I will try this.
It is a nat exemption so that outside addresses no not get nat'ed when they are headed for your network. You have a nat 0 on your inside that says permit any to 172.19.15.0.
Traffic from your remote office was not being nat'ed when going to 172.19.15.0. Now we use the same ACL, add the lines that showed you and apply it to the outside, so when traffic from 172.19.15.0 is going to 192.168.7.0 and 192.168.8.0 it is not nat'ed.
I added nat (outside) 0 access-list inside_outbound_nat0_acl and all my inside nat rules were copied to the outside is this right?
I failed to mentions these static Nat's too, does this matter?
static (inside,outside) 80.171.16.67 VO09 netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.68 A-SERVER netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.72 p_server netmask 255.255.255.255
static (DMZ1,outside) logger logger netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.78 PRS netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.84 Videocom netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.94 Top netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.74 LCD netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.93 bottom netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.79 Player2 netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.80 Player1 netmask 255.255.255.255
static (DMZ2,outside) Dial-up Dial-up netmask 255.255.0.0
static (inside,DMZ2) 128.101.10.4 SV6 netmask 255.255.255.255
static (inside,outside) 80.171.16.92 Xe_7245_ netmask 255.255.255.255
static (inside,DMZ4) SV02 SV02 netmask 255.255.255.255
static (inside,DMZ4) VO005 VO005 netmask 255.255.255.255
static (inside,outside) 80.171.16.77 SV06 netmask 255.255.255.255
static (inside,DMZ1) MOrver MOrver netmask 255.255.255.255
static (inside,DMZ2) MOrver MOrver netmask 255.255.255.255
static (inside,DMZ1) VO1 VO1 netmask 255.255.255.255
static (inside,DMZ1) Andr Andr netmask 255.255.255.255
static (inside,outside) 80.171.16.88 SV10 netmask 255.255.255.255
static (DMZ1,outside) 80.171.16.89 Uafits netmask 255.255.255.255
i have run:
debug crypto ipsec 127
debug crypto isakmp 127
remote office = IP 1.2.3.4
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, Removing peer from correlator table failed, no match!
Apr 09 16:43:43 [IKEv1 DECODE]: IP = 1.2.3.4, IKE Responder starting QM: msg id = e46b66a3
Apr 09 16:43:43 [IKEv1]: IP = 1.2.3.4, IKE_DECODE RECEIVED Message (msgid=e46b66a3) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NONE (0) total length : 172
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, processing hash payload
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, processing SA payload
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, processing nonce payload
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, processing ID payload
Apr 09 16:43:43 [IKEv1 DECODE]: Group = 1.2.3.4, IP = 1.2.3.4, ID_IPV4_ADDR_SUBNET ID received--172.19.15.0--255.255.255.0
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, Received remote IP Proxy Subnet data in ID Payload: Address 172.19.15.0, Mask 255.255.255.0, Protocol 0, Port 0
Apr 09 16:43:43 [IKEv1 DECODE]: Group = 1.2.3.4, IP = 1.2.3.4, ID_IPV4_ADDR_SUBNET ID received--0.0.0.0--0.0.0.0
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, Received local IP Proxy Subnet data in ID Payload: Address 0.0.0.0, Mask 0.0.0.0, Protocol 0, Port 0
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, QM IsRekeyed old sa not found by addr
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, Static Crypto Map check, checking map = outside_map, seq = 1...
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, Static Crypto Map check, map = outside_map, seq = 1, ACL does not match proxy IDs src:172.19.15.0 dst:0.0.0.0
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, IKE Remote Peer configured for crypto map: SYSTEM_DEFAULT_CRYPTO_MAP
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, processing IPSec SA payload
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, All IPSec SA proposals found unacceptable!
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, sending notify message
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, constructing blank hash payload
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, constructing ipsec notify payload for msg id e46b66a3
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, constructing qm hash payload
Apr 09 16:43:43 [IKEv1]: IP = 1.2.3.4, IKE_DECODE SENDING Message (msgid=920f1396) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 84
Apr 09 16:43:43 [IKEv1]: Group = 1.2.3.4, IP = 1.2.3.4, QM FSM error (P2 struct &0xc94c2f88, mess id 0xe46b66a3)!
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, IKE QM Responder FSM error history (struct &0xc94c2f88) , : QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Apr 09 16:43:43 [IKEv1 DEBUG]: Group = 1.2.3.4, IP = 1.2.3.4, sending delete/delete with reason message
Can you post the config from the router.
Hi Smitty,
The config is attached up the top of this forum post.
also should I have some "access-list encrypt-acl extended permit ip" in my config somewhere?
