Rogues? What Rogues?
Apr 9th, 2008
Hi All,
As I type the WCS Home page is reporting that I have a total of 59 rogue APs in the 'Rogue Detail Summary" table. However, when I click on the red underlined '59' WCS takes me to the rogue AP page and, guess what, the page is blank! Up until a few days ago this page was working ok. Has anybody else came across this?
Any help as ever will be greatly appreciated.
Overall Rating: 2 (1 ratings)
ericgarnel Wed, 04/09/2008 - 05:26
What rev of wcs, wlc and location app are you running? Also, what are the setting under Adminstration|Settings in WCS?
scottwilliamson Fri, 04/11/2008 - 07:18
Hi Eric,
Thanks for your help
WCS is
WLCs are
no location appliances
The settings in admin/settings should all be at the defaults as I have not made any changes to them. However....
Data Management 31, 31, 10, 31
Report "filepath", 31
Mail Server - all blank except 'From' - WCS@"WCSIP"
Login Disclaimer - Blank
Alarms unchecked, checked, unchecked
Client unchecked
Notification Receiver - None
SNMP unchecked, Exponential, checked, 2, 2, 100
Also, if I click on the number of adhoc Rogues on the Home page then that table displays OK.
The alarm summary table in the bottom left of the browser widow displays 0 rogues when the table on the Home page says 60.
scottwilliamson Mon, 04/14/2008 - 00:50
Hi Eric,
Its a Linux system.
I tried restarting the service and rebooting - neither made any difference I'm afraid.
Thanks for trying
scottwilliamson Mon, 04/21/2008 - 04:57
I've discovered I can get to the expected data if I select 'Monitor','Security'the click on the number of "Unclassified Rogues".
It sounds like a bug indeed.
Trending Topics - Security & Network
