04-09-2008 02:37 AM
I found a h323 gateway can't make any international calls thru a gatekeeper.
From the debug log, the gatekeeper doesn't send an ACF to the gateway after received a LCF from another gatekeeper.
Is it a know bug or configuration issue? Attached is the debug file.
Thanks in advance.
Rgds,
Ivan Cheng
hq01#csim start 6568465338
hq01#show log
Syslog logging: enabled (0 messages dropped, 15 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level debugging, 3799 messages logged
Monitor logging: level debugging, 480 messages logged
Buffer logging: level debugging, 3813 messages logged
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level notifications, 583 message lines logged
Logging to 155.161.76.72, 583 message lines logged
Logging to 155.161.135.135, 583 message lines logged
Logging to 192.170.75.40, 583 message lines logged
Log Buffer (4096 bytes):
00 44004200 34004500 31003800 30003000 30003000 30003000 33003900 00000000 00000000 00000000 00000000 FA232100 11000000 00000000 00000000 00000000 00000100
Apr 3 14:08:20 GMT:
Apr 3 14:08:20 GMT: csim_do_test: cid(475), ev(11), disp(0)
Apr 3 14:08:20 GMT: csimTraceSct: cid(475),st(0),oldst(0)
Apr 3 14:08:20 GMT: csim err csimDisconnected recvd DISC cid(475)
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: (callID=0x1DB, cause=0x3F tag=0x0)
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: calling accounting start for callID=475 leg_type=0
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: existing_cause = 0x3F, new_cause = 0x3F
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: using the existing_cause 0x3F
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/cc_api_get_transfer_info: (callID=0x1DB)
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[475], tagID[30], instID[-1]
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableObjectAccessManager: No profileTable set for callID[475]
Apr 3 14:08:20 GMT: //475/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[30] of callID[475]
Apr 3 14:08:20 GMT: H.225 SM: process event H225_EVENT_RELEASE, for callID 1DBcch323_run_h225_sm: received event H225_EVENT_RELEASE while at state H225_WAIT_FOR_RAS_CONF
cch323_run_h225_sm: Unexpected event[9] in CCH323_H225_STATE_WAIT_FOR_RAS_CONF state
Apr 3 14:08:20 GMT: H.225 SM: changing from H225_WAIT_FOR_RAS_CONF state to H225_WAIT_FOR_DRQ state for callID 1DB
Apr 3 14:08:20 GMT: RAS INCOMING ENCODE BUFFER::= 40 1EA8
Apr 3 14:08:20 GMT:
Apr 3 14:08:20 GMT: RAS INCOMING PDU ::=
value RasMessage ::= disengageConfirm :
requestSeqNum 7849
Apr 3 14:08:20 GMT: H.225 SM: process event H225_EVENT_RAS_SUCCESS, for callID 1DBcch323_run_h225_sm: received event H225_EVENT_RAS_SUCCESS while at state H225_WAIT_FOR_DRQ
Apr 3 14:08:20 GMT: H.225 SM: changing from H225_WAIT_FOR_DRQ state to H225_IDLE state for callID 1DB
Apr 3 14:08:20 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif: expect factor = 0
Apr 3 14:08:20 GMT: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 0 0 0 0, SetupTime 14:08:04.217 GMT Thu Apr 3 2008, PeerAddress 6568465338, PeerSubAddress , DisconnectCause 65 , DisconnectText message in incomp call state (101), ConnectTime 14:08:20.637 GMT Thu Apr 3 2008, DisconnectTime 14:08:20.637 GMT Thu Apr 3 2008, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
04-09-2008 06:47 AM
Ivan,
Can you turn on "debug gatekeeper main 10", make the call and post the output?
Brandon
04-10-2008 06:23 PM
04-14-2008 06:06 AM
Ivan,
Can you post the configuration from the gateway and gatekeeper?
Brandon
