NAC Login Script
Apr 9th, 2008
Have CAM/CAS in OOB L2 Virtual Gateway working with AD SSO assigning the access VLAN based on group membership in the AD. Need to get the login scripts to run.
The information for adding a delay as per page 9-6 of the CAS manual v4.1.3 doesn't work. The errorlevel returned for successful and unsuccessful ping attempts is the same; errorlevel 0.
Does anyone have a test of network connectivity that will produce a errorlevel of 1 for failure and errorlevel of 0 for success?
ddrodge Wed, 04/09/2008 - 07:22
Used dir \\servername\share to successfully test the network connectivity. NAC authenticated users now run the login script after the CCA agent changes the IP.
