VPN problem
Apr 9th, 2008
we have firewall pix 515e sofwear v7.0, we use it as a VPN server to one company, can i make another vpn connection with diffrent configuration to another company or client ?
regards
husycisco Wed, 04/09/2008 - 05:32
  • Gold, 750 points or more
Hi Ahmed
Sure you can. Your peer limit is defined in you license. You can type sh ver and see it.
alalem2005 Wed, 04/09/2008 - 09:48
thanks for quick replay, my 515 license is unrestricted , when i try to add new VPN configuration it seems like not response and it stopes in first step (i am using ASDM), just i can't even choose the interface.
husycisco Wed, 04/09/2008 - 10:12
That must be a bug in 7.0. Upgrade your IOS to 7.2, also upgrade your ASDM image
