can i use pos 622M as a pos 155M interface, module is SPA-1XOC12-POS
Answered Question
Apr 9th, 2008
SPA-1XOC12-POS can use as a 155M sdh POS interface?
this is on 7609 sip 400,not a channelized oc 12 interface.
if i connect a 155 M sdh line into this 622M interface,it is single mode fiber. does this work?
thank you!
Correct Answer by s.schlegel about 9 years 2 days ago
Hi flyjunli,
I'm quite sure this won't work. The framing won't fit if you connect different interfaces.
BR
Sebastian
Overall Rating: 4 (1 ratings)
j-block Tue, 04/15/2008 - 05:13
hmmmm....I don't think this is supported. Anyone else know this?
Correct Answer
s.schlegel Sat, 07/19/2008 - 07:51
Hi flyjunli,
BR
Sebastian
