How to bind different IP addresses based on the PSTN physical line?
Apr 9th, 2008
I have the following case: Two E1 interfaces to the PSTN. An incoming call comes and I want to send it to the CallManager with different IP addreses (loopback) based on the E1 line. My target is to allow 7 incoming digits for the first E1 and 4 digits for the second E1.
Thank you.
Best Regards,
Zdravkov
paolo bevilacqua Wed, 04/09/2008 - 06:02
  • Hall of Fame,
    Founding Member
Hi, first of all if the CM is only one, you don't need to send to different addresses, you can strip digits easily with a translation-profile at voice-port level.
But if there were two CMS and a single GW, you could use two techniques, cor and "steering digits" Both have separate incoming DP based on "incoming called-number". With COR, you distinguish which DP outgoing to use, based on COR settings. With "steering digits", the incoming DP adds a certain number to match an outgoing DP, tha number is the stripped out via translation-profile.
