Scientifc Atlanta to C871
Apr 9th, 2008
I have got a cable modem (model above) connected via ethernet to a C871 with 1 Fastethernet port and 4 L2 ports.
I have configured the following so that I can ping the gateway of my ISP. I have been given a static IP address.
Router#sh run
Building configuration...
Current configuration : 899 bytes
version 12.4
no service pad
hostname Router
no aaa new-model
resource policy
ip subnet-zero
ip cef
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description OUTSIDE
ip address 82.x.x.72
ip access-group 100 in
ip access-group 100 out
duplex auto
speed auto
interface Vlan1
no ip address
no ip classless
ip route
no ip http server
no ip http secure-server
access-list 100 permit ip any any log
access-list 100 deny ip any any log
I am unable to ping the GW address but I can ping this GW if the cable modem is connected straight into my PC.
Can anyone suggest why? I tried using both cross-over and straight between the cable modem and the router. Same outcome.
scristian Thu, 04/10/2008 - 01:16
After you connect the cisco 871 to the cable modem, call the ISP and tell them to clear cable host or to reset the modem and clear the arp's.
victor888 Thu, 04/10/2008 - 01:31
Problem was resolved by turning off the modem for 30 seconds whilst having the router off as well. Then turning the modem back on followed by the router. This was necessary since there modem has some type of mac-address-lock down mechanism only accepting the 1st MAC after initial bootup. My laptop was initally used to test connectivity hence the router was not being allowed through.
Thanks for your help anyway
