ACS routing question
Apr 9th, 2008
I have some routers at remote locations that Im trying to get talking with my new ACS server. All the IP's we use are public, so when I tell the router to talk to ACS at 201.x.x.x, which is behind my ds3, its actually going to 201.x.x.x in another country. My question is this; what would be the best way to get my routers pointed to the correct 201.x.x.x address?
sdrossen2 Wed, 04/09/2008 - 07:14
Just to clarify, your using a public ip (201.x.x.x) internally that is not assigned to you?
richardcalvert Wed, 04/09/2008 - 07:18
Correct. It's actually private behind our ds3, but our private IP's match public IP's.
richardcalvert Wed, 04/09/2008 - 11:18
also, the routers that have the 201.x.x.x IP addresses are behind gateways with static IPs.
So I need the private 201.x.x.x addressed routers to communicate with the private 201.x.x.x ACS server.
