Change IP address on Publisher in cluster
Rob Huffman Wed, 04/09/2008 - 08:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
We have successfully used the steps in this doc;
Changing the IP Address for Cisco Unified CallManager / Unified Communications Manager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094601.shtml
Note: If you have Subscribers, when you change the IP address of the Publisher, you need to edit the LMHOST files in the Subscribers to the new IP address
Hope this helps!
Rob
mattcalderon Wed, 04/09/2008 - 16:57
  • Silver, 250 points or more
Excellent document Rob. I did read the document and did not find it all inclusive as I would have expected from cisco. It does reference your JTAPI integration, Unity integration, and even your DHCP option 150 but nothing about your gateways. If you are using an H323 gateway your voip dial-peers will have to reflect the new ip and if using mgcp, portions of your configuration would have to change as well.
