Internal DHCP Server on 4402 controller
I am trying to setup a guest vlan. I set up an interface for the guest vlan on my 4402 controller. I assigned the guest vlan interface an IP of 192.168.2.10 with a 24 bit subnet mask.
This vlan will go to my DMZ where there is no DHCP server so I need to setup the internal DHCP server. I created a new scope but I'm having trouble with what to put in the Network field for the DHCP scope. The pool addresses are 192.168.2.100-200. with a 24 bit subnet mask.
Every time I try to apply the configuration I get an "error in setting DHCP scope network and netmask".
I've tried using:
192.168.2.10
192.168.2.255
192.168.2.254
as entries for the Network setting but no go. The docs say to enter the IP address used by the management interface with subnet mask applied.
I was assuming they meant the interface for the guest vlan.
What am I doing wrong here?
Thanks.
jason_mueller Mon, 08/06/2012 - 21:57
I know this is an old post but could you please tell me what your solution was
Amjad Abdullah Mon, 08/06/2012 - 23:36
  • Red, 2250 points or more
Jason:
This is an old post with probably very old code version on the controller.
If you want help please feel free to open a new thread and explain your issue so we better help you.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
