managing SSL certifications
Answered Question
Apr 9th, 2008
I have configured on the CSS content rules for SSL traffic without using the SSL module and SSL proxy list but I noticed some issues regarding to the correct acquisition of the SSL certificate from the client side.
I would like to know if configuring the CSS as transparent Gateway for SSL can create those issues.
Moreover, how could I check it on CSS?
The CSS configuration is the following:
content HTTPS
port 3453
protocol tcp
vip address 10.1xx.x.x
add service server_SSL_1
add service server_SSL_2
advanced-balance ssl
application ssl
active
keepalive port 3456
ip address 10.1xx.x.y
port 3456
active
keepalive port 3456
ip address 10.1xx.x.z
port 3456
active
Thank you very much.
Best regards.
Giuseppe
Correct Answer by Gilles Dufour about 8 years 10 months ago
I do not know any issue about acquisition of client cert.
Normally the CSS will just wait for the client ssl hello to detect the sslid but it will then pass all the information transparently to the server and the ssl handshake will continue between client and server.
Get a sniffer trace on the server to see what is going on.
Gilles.
Overall Rating: 4 (1 ratings)
Correct Answer
Gilles Dufour Thu, 04/10/2008 - 03:46
Gilles.
gpangallo Thu, 04/10/2008 - 05:10
Hi Gilles,
Thank you for your support.
I thought the same thing but I wasn't sure and I would know your opinion.
Regards.
Giuseppe
