Intteruption/inteferences to wireless communication
Apr 9th, 2008
dear sir,
We wish to setup 4-5 cisco wireless access points AIR-AP1242AG on area that surround with radio x . We are not sure for the radio x impact on wireless ap implementation. We just afraid it might happen explosion or any negative impact might happen if we install ap there.Please advise or anyone have any document that can tell us the wireless impact with radio x / rf intererence and environment that could lead to wireless negative impact. How to measure the trace and measure the inteferences?
thanks and your effort shall be highly rated.
Overall Rating: 3 (1 ratings)
Scott Fella Wed, 04/09/2008 - 14:35
What is radio X? You should find out what frequency radio x operates on. As you know, if radio x runs either on 2.4GHz or 5GHz, you will most likely have interference. If you happen to not know what frequency radio x is using, then you will have to get a hold of a spectrum analyzer to see if radio x is using one of the frequencies.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
