PIX 501 running 6.3 startup-config
Answered Question
Apr 9th, 2008
I have several remote PIX 501s that have VPNs back to my location. I have remote telnet access via the VPN connection. I would like to change the configurations so the VPNs terminate to my ASA rather than my older 3030. Is there anyway to modify the startup-config on a PIX 501 running 6.3? There is no copy tftp start-up command, only a configure net command which merges the config to running. This wont work for me since I need to also change inside IP addresses which is how I am connected. I really need to change startup config and reload.
Thanks. Doug
Correct Answer by acomiskey about 8 years 11 months ago
Try...
ca gen rsa key 1024
ssh 0 0 outside
Correct Answer by srue about 8 years 11 months ago
the best solution (and easiest) i've found for that situation is to configure ssh to the outside interface from just the IP you're coming from...
then ssh into it and change peers, your ssh session won't be disconnected then, and you can still troubleshoot remotely.
Overall Rating: 5 (2 ratings)
Correct Answer
srue Wed, 04/09/2008 - 09:03
  • Blue, 1500 points or more
dbuttry Thu, 04/10/2008 - 07:15
Thanks for your reply however I can not get that to work. I even tried telnet (i know thats not secure) and still can not connect to it. Even tried changing "management-access inside" to outside and locked myself out of one until I had them reboot. Any ideas? Thanks!
Correct Answer
acomiskey Thu, 04/10/2008 - 07:19
  • Green, 3000 points or more
Try...
ca gen rsa key 1024
ssh 0 0 outside
dbuttry Thu, 04/10/2008 - 07:35
Thanks so much! Once I figured out to use "pix" as the username and {telnet password} as the password, I'm in!
srue Thu, 04/10/2008 - 09:37
yeah, the username pix throws off a lot of people....
thanks for the rating btw.
