CCME AA Error:nested exception is:java.lang.NullPointerException
Apr 9th, 2008
Hi Guys,
I am trying to add a customized aa to CCME and when I debug the script I get the following error:
Task creation failed: Failed to preprocess the application:wyless.aef; nested exception is:java.lang.NullPointerException
when I do a trace config-ccn all and trace config-ccn application all..I get the same error:
What can I check..
ebreniz Tue, 04/15/2008 - 05:28
This sounds like you have IE incorrectly configured. Please verify your settings. Goto Tools -> Internet Options -> Temporary Internet Files (Settings) and set Check for newer versions of stored pages to Every visit to the page.
