David Stanford Thu, 04/10/2008 - 08:05
  • Cisco Employee,
For Jitter have a look at the objects under the rttMonJitterStatsTable
For packetloss look at rttMonJitterStatsPacketLossSD and rttMonJitterStatsPacketLossDS
For delay:
rttMonLatestJitterOperOWSumSD rttMonLatestJitterOperOWSum2SD
rttMonLatestJitterOperOWMinSD
rttMonLatestJitterOperOWMaxSD rttMonLatestJitterOperOWSumDS rttMonLatestJitterOperOWSum2DS rttMonLatestJitterOperOWMinDS rttMonLatestJitterOperOWMaxDS rttMonLatestJitterOperNumOfOW
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&submitClicked=true&mibName=CISCO-RTTMON-MIB#contents
shivaniwagh Thu, 04/10/2008 - 08:50
But any one of the OID can be the data for delay??
for jitter I have used this rttMonLatestJitterOperMaxOfPositivesSD & rttMonLatestJitterOperMaxOfNegativesSD as well for rttMonLatestJitterOperMaxOfPositivesDS & rttMonLatestJitterOperMaxOfNegativesDS
I have one more query.I am not able to understand the Jitter Stats Table,as it gives two values.Ex.
snmpwalk $ip 1.3.6.1.4.1.9.9.42.1.3.5.1.12
Result:
cisco.ciscoMgmt.42.1.3.5.1.12.2.4214297322 : Counter: 148
cisco.ciscoMgmt.42.1.3.5.1.12.2.4214657322 : Counter: 11
Please help me to understand this,why it gives two values.?
Shivani
David Stanford Fri, 04/11/2008 - 06:08
  • Cisco Employee,
How many jitter operations have you configured? It looks like 2 as there are 2 different indices above -- 4214297322 and 4214657322
These each are the sum of number of all positive jitter values from packets sent from source to destination
shivaniwagh Fri, 04/11/2008 - 08:56
Yes the MIB of rttMonJitterStats gives me the values for the two indices.I have no idea why its giving two.for latest it gives for only one..
UTVi-NetAdmin Mon, 06/16/2008 - 07:10
Hi Shivani,
Some of these entries hold information for two hours, witht the statistics being grouped together over 60 minutes, hence the 2 sets of values.
The last value is the most current. These are then moved to the other entry and are removed from table after 120 minutes. i.e. a 'sliding window'.
HTH,
Mark
