Policy based routing and Floating routes
Answered Question
Apr 9th, 2008
I have following configurations in one router and i am not been able to fetch the details thay y are they used. kindly suggest me some link or info regarding this
rtr 1
type echo protocol ipicmpecho 192.168.52.34
rtr schedule 1 life forever start-time now
track 192 rtr 1 reachability
int x
ip policy route-map ABC_MAP
route-map MIXIT_MAP
set ip next-hop verify-availability 192.168.52.34 10 track 192
ip route xx.xx.xx.241 255.255.255.255 192.168.52.34 track 192
ip route xx.xx.xx.241 255.255.255.255 ABC_INTERNET_INTERFACE 254
Correct Answer by sundar.palaniappan about 8 years 9 months ago
Yes, there's no drawback. As soon as 192.168.52.34 becomes reachable the primary route will be used.
Overall Rating: 5 (1 ratings)
imranraheel Wed, 04/09/2008 - 10:37
Is there any draw back will I be able to get the route back if i will get the connectivity back to xx.xx.xx.241 via 192.168.52.34
Correct Answer
sundar.palaniappan Wed, 04/09/2008 - 10:48
imranraheel Tue, 04/15/2008 - 13:32
I am trying to implemet the following configurations
rtr 1
int x
route-map ABC_MAP
ip route xx.xx.xx.241 255.255.255.255 xx.xx.xx.2 254
But when ever i try this i receive an error (command support issues)on verify-availability
I am using 3550 with (C3550-IPSERVICESK9-M), Version 12.2(35)SE IOS.
Kindly put some light on this
