4402 controller - Internal DHCP - Clients don't get addresses
I am working on setting up a WLAN for guests to use for Internet access. I set up a WLAN and used a VLAN to seperate it from my prod network.
I set up a dynamic interface called guestvlan. IP is: 192.168.2.10/24. Under primary DHCP I put the management interface IP for the controller: 172.16.0.94.
I setup the Internal DHCP server to service network 192.168.2.0/24.
The guest WLAN is set to use the guestvlan interface.
I can authenticate to the guest WLAN. But then the client stays stuck on "acquiring IP address".
Any help greatly appreciated.
Overall Rating: 4 (1 ratings)
fcollett Wed, 04/09/2008 - 11:54
Check to make sure your controller interface is connected to a trunk on your switch which permits all the dynamic vlans and your management interfaces.
Also, check to make sure your access point is connected to an access port assigned to the management vlan (same as the controllers management interface).
Let me know how that goes.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
