IE7 and CCME GUI: tricks to making it work?
Apr 9th, 2008
I'm setting up a phone lab with a 2811 router and have only IE7 to use to connect to the CCME GUI. The login request comes up, and upon successful login, the first page with tabs. But i can not get any further. The tabs do not respond. Yes, pop-up blockers are off, and I even shutdown the pc firewall for a couple of tests with no change. I'm running XP and have tried to move back to IE6 with instructions from MS site, but to no avail. Any ideas?
Ps. CUE GUI does work with IE7.
Michael Mistretta Wed, 04/09/2008 - 19:20
Doing a simple uninstall on IE7 did not work? There is a setting in Internet Options>general, down by tabs, settings,open links from other programs. Have you tried adjusting this?
