Site to Site and Remote Access VPN
Apr 9th, 2008
I have to connect two offices using 1841 routers . I just have an issue both the sides are behind a single subnet and I have to do NATTING. The issue is how will be the router able to manage that which IP exist at which site. The same issue exist with Remote VPN as well I have made a VPN pool with different IP and have add a route but the issue remains the same and i m still not been able to ping the IPs on the 2nd side
jbayuka Tue, 04/15/2008 - 06:01
A document exists where PIX/ASA maintains LAN-ti-LAN IPsec tunnel at two end points and there is overlapping networks at ther inside interface of both the asa. Probably, the basic configuration for both asa and IOS routers are nat config. So, this particular document might be useful for your requirement
PIX/ASA 7.x and later: Site to Site (L2L) IPsec VPN with Policy NAT (Overlapping Private Networks) Configuration Example
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808c9950.shtml
