Internet access from VLAN on Catalyst 2960
Apr 9th, 2008
I have a Catalyst 2960 switch and a Cisco 5510 ASA router operating as the firewall. I created a VLAN on a Cisco Catalyst 2960 and I have created the VLAN interface on the ASA.
I am having problems after I assign a static IP to the workstation, I cannot surf the web?
Please help!
evsrajatgupta Wed, 04/09/2008 - 12:30
Hi marcusfleming,
(Please rate)
You need to config Default gateway on the switch. Default gateway should be Ip address of AsA.
marcusfleming Thu, 04/10/2008 - 05:07
See configurations below. Currently that information already exists in the 2960.
Edison Ortiz Wed, 04/09/2008 - 13:18
  • Hall of Fame,
    Founding Member
If you assign an static IP to a workstation, there is additional information that needs to be provided - which usually is taken for granted when receiving an IP via DHCP.
Have you entered the DNS and default gateway information on this workstation?
Based on your post, the ASA is your default gateway as the 2950 is just a Layer2 switch, can you ping the ASA from this workstation?
__
Edison.
marcusfleming Thu, 04/10/2008 - 05:02
Here are the configs from the ASA and the 2960. The VLAN that I have set up is the "test_vlan" VLAN 20.
ASA config:
interface Ethernet0/0
speed 100
duplex full
nameif outside
security-level 0
ip address 12.x.x.x 255.255.255.224
ospf cost 10
interface Ethernet0/1
speed 100
duplex full
no nameif
no security-level
no ip address
interface Ethernet0/1.1
shutdown
no vlan
no nameif
no security-level
no ip address
interface Ethernet0/1.6
vlan 6
nameif inside
security-level 100
ip address 10.114.6.1 255.255.255.0
ospf cost 10
interface Ethernet0/1.20
vlan 20
nameif test_vlan
security-level 100
ip address 10.114.8.1 255.255.255.0
ospf cost 10
Cat 2960 config for int fa0/47:
hostname SW2960_A1
logging buffered informational
enable secret xxx
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
udld aggressive
ip subnet-zero
ip domain-name test.com
mls qos map cos-dscp 0 8 16 26 32 46 46 56
macro global description cisco-global
errdisable recovery cause link-flap
errdisable recovery interval 60
no file verify auto
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree vlan 1-2048 priority 24576
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 6
switchport mode access
macro description cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet0/2
switchport mode trunk
speed 100
duplex full
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/47
switchport access vlan 20
interface FastEthernet0/48
speed 100
duplex full
interface GigabitEthernet0/1
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
interface GigabitEthernet0/2
media-type rj45
interface Vlan1
no ip address
no ip route-cache
interface Vlan6
ip address 10.114.6.12 255.255.255.0
no ip route-cache
ip default-gateway 10.114.6.1
ip http server
control-plane
line con 0
line vty 0 4
password xxx
login
line vty 5 15
password xxx
login
ntp clock-period 36028879
ntp server 130.207.244.240
end
(Some of the information has been stripped but for the most part it should all be in there.)
I have assigned a static IP to the workstation with the following information:
IP: 10.114.8.2/24
DG: 10.114.8.1
DNS: 10.114.6.10 (DNS server on main network)
With this information and settings, I am not able to ping the ASA from the workstation
Edison Ortiz Thu, 04/10/2008 - 05:18
  • Hall of Fame,
    Founding Member
I'm not very familiar with the ASA hardware but you should be able to ping the ASA interface if the interface from the 2960 is trunked toward the ASA.
What switchport is being used for this connection?
You may also want to make sure the Native Vlan matches between the trunk. By default, the Native Vlan on a switch is Vlan1. If the ASA is using another native Vlan, the trunk may fail.
You may want to repost in the FW section of this forum where the ASA experts hang out.
HTH,
__
Edison.
