Remote Access VPN on PIX515E
Apr 9th, 2008
My setup is;
I am using PIX515E on my LAN. Outside Interface: Public IP 66.X.X.X
Inside network: 10.X.X.X
I want to terminate remote access VPN on the inside network.I used ASDM VPN wizard to create the VPN setup without any luck. What is the best way to set this up? Thanks.
JORGE RODRIGUEZ Wed, 04/09/2008 - 17:28
Kaleem,
This link should give you step by step to setup RA either through asdm/pdm or cli,If you have already implemented it what seems to be the problem.
"I want to terminate remote access VPN on the inside network"
Im not quite clear here on this question, you want to terminate the tunnel in your inside interface or outside interface? where will the users connections be comming from ? if RA users will be connecting to your network via internet the interface in your pix facing internet is the interface one terminates the tunnel on, in any case if you have an interface other than the outside interface where you terminate the tunnel the same principle applies assuming the RA connections will be comming to the pix on a different interface.
RA
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
Rgds
Jorge
