Option 43 and CNR 6.2.3.1
sdbrockme
I'm having a hard time setting up option 43. The standard command in nrcmd gives the following output.
nrcmd> vendor-option
322 Feature not supported - incompatible cluster version
nrcmd> help vendor-option
500 - cannot open help file /opt/nwreg2/local/docs/nrcmd/vendor-option.txt
It doesn't look like vendor-option even exists on this version. It looks like the command is now 'option'.
Anybody got any ideas.
andrew.prince
Level 10
Level 10
You would normally add option 43 in the ip DHCP pool configuration, supply the rest of your DHCP config?
kevin_miller
Did you figure this out?? I've got the same issue. Thanks!
lfabricio
Hi sdbrockme,
Try the command option-set rather than vendor-option, like the example below:
nrcmd> option-set aironet1200 create 8-bit vendor-option-string="Cisco AP c1200"
100 Ok
Leandro Oliveira
