04-09-2008 01:26 PM - edited 03-03-2019 09:29 PM
Does Cisco IOS XE Software use the same command-line interface (CLI) as Cisco IOS Software?
04-10-2008 04:03 AM
The ASR 1000 CLI will be similar to other IOS versions. But as always, there will be platform specific commands (like e.g. for a GSR) and minor differences. 3800 series routers and Catalyst 6500 both use IOS, yet you might find several differences in commands and features being available. So do not expect that you can copy and paste a 3800 or 6500 configuration into an ASR 1000 without any hickup :-)
Regards, Martin
04-18-2008 05:06 AM
I want to ask when will be available Software Configuration Guide for ASR 1000 IOS XE?
Thanks!
Momchil
04-01-2012 04:01 AM
Can you please confirm to me is the below steps is the right steps to upgrade ASR 1002&1006
and why we need to add /auto/tftp-users/user why not the IOS only as like normal upgrade for 6500 series
/auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
Router# dir bootflash:
Directory of bootflash:/
11 drwx 16384 Dec 4 2007 04:32:46 -08:00 lost+found
86401 drwx 4096 Dec 4 2007 06:06:24 -08:00 .ssh
14401 drwx 4096 Dec 4 2007 06:06:36 -08:00 .rollback_timer
28801 drwx 4096 Mar 18 2008 17:31:17 -07:00 .prst_sync
43201 drwx 4096 Dec 4 2007 04:34:45 -08:00 .installer
13 -rw- 45977 Apr 9 2008 16:48:46 -07:00 target_support_output.tgz.tgz
928862208 bytes total (712273920 bytes free)
Router# copy tftp bootflash:
Address or name of remote host []? 172.17.16.81
Source filename []?
Destination filename [asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin]?
Accessing
tftp://172.17.16.81//auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bIN
Loading /auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin from
172.17.16.81 (via GigabitEthernet0):
[OK - 208904396 bytes]
208904396 bytes copied in 330.453 secs (632176 bytes/sec)
12 -rw- 208904396 May 28 2008 16:17:34 -07:00
928862208 bytes total (503156736 bytes free)
Router# config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#boot system flash
bootflash:asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
Router(config)#config-reg 0x2102
Router(config)#exit
Router#show run | include boot
boot-start-marker
boot system flash bootflash:asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
boot-end-marker
Router# copy run start
Destination filename [startup-config]?
Building configuration...
[OK]
Router# reload
04-01-2012 02:45 PM
Copy the IOS into the ASR's bootflash.
04-01-2012 10:16 PM
Source filename []?
Accessing
Why i need to add the below line
or just put only the IOS
asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin without
