upgrade/downgrade to 6.0.0-745
Apr 9th, 2008
I have a C350 running on 6.0.0-745 and just received a second box to make a cluster. The new box runs on version 5, but can't get upgraded to 6.0.0-745. 6.0.0-746 or 6.0.0-747 are the only choices. Is there a way to get the 6.0.0-745 image? I can't update the box that I have, because this would mean downtime of my email services.
Doc_ironport Wed, 04/09/2008 - 17:48
Support will be able to give you access to 6.0.0-745 - just raise a call with them.
I'd still suggest upgrading to 6.0.0-747 as it's got a few bug fixes over -745.
floyd_ironport Thu, 04/10/2008 - 11:52
thanks, Doc
as soon as I have 745 on the second box and the cluster running, I will update both boxes to 747. I just don't want to make all configuration settings on the second box (yes, I am very lazy)
