Static Policy
Apr 9th, 2008
I need to NAT an internal server and allow only certain ports open. After creating access-lists for these ports, should I still enable PAT (for the said ports) in the NAT configuration?
Thanks!
husycisco Thu, 04/10/2008 - 03:41
  • Gold, 750 points or more
Hi Patricia,
If you applied a one-to-one NAT like following
static (inside,outside) publicip localip netmask 255.255.255.255
Then you dont need to specify these ports individually.
But if you applied PAT, you should forward these ports as following
static (inside,outside) tcp interface portno localip portno netmask 255.255.255.255
