Call handling configuration using CCM 4.2
ciscomanii
I want to setup a private extension that will be dialed from my company's CCM 4.2 / Unity 4.0 Opening Greeting that will contact each member of my IT unit
by ringing their deskphone DN, their Mobile phone and their home phone. I know that CUCM 6.0 has the Presence feature but we are not looking to upgrade at this point and time and need a workaround, any ideas???? thx
Jaime Valencia
what you're looking for is not the Presence feature but Unified Mobility, those are different things
you could try the notification devices on Unity (of course it won't work the same way) or add a Mobility Manager server to the cluster so you can accomplish the behavior you're looking for.
javalenc
if this helps, please rate
java
