callmanager to callmanager
Answered Question
Apr 9th, 2008
dear all
i have two branch office , each one has its pwn ccm, but now they decided that they ip phones connects to each other.
i think of ip-to-ip-gateway..is it true?
Correct Answer by Paolo Bevilacqua about 8 years 9 months ago
Make IP connectivity, then configure "inter-cluster trunks" as described in the CM manual.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Thu, 04/10/2008 - 00:51
Hi, When you have IP connectivity between the two offices, you don't need ip-to-ip gw to link the CMs.
hope this helps, please rate post if it does
Correct Answer
Paolo Bevilacqua Thu, 04/10/2008 - 07:24
