ATM on Cisco 3620/3640
Apr 9th, 2008
Hi Gurus,
Can either of this be used for the ATM connection? And if yes, please let us know the relevant modules and cables required for this.
cisco 3620 (R4700) processor (revision 0x81) with 61440K/4096K bytes of memory.
Processor board ID 21941406
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
System image file is "flash:c3620-d-mz.120-7.XK1.bin"
OR
cisco 3640 (R4700) processor (revision 0x00) with 76800K/5120K bytes of memory.
Processor board ID 19593507
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
1 ISDN Basic Rate interface(s)
16 terminal line(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
System image file is "flash:c3640-do3s-mz_120-7_xk1(1).bin"
Paolo Bevilacqua Wed, 04/09/2008 - 23:41
I recommend you use the newer ISR router for ATM connections. The 36xx beside being not supported anymore, are generally quite slow and do not do a good service. Beside, the ones you have would need upgrade for both flash and ram.
Joseph W. Doherty Thu, 04/10/2008 - 05:11
Both might be, although Paolo makes a good point in noting the 36xx series is end-of-life.
For ATM cards, see "ATM Network Modules" within http://www.cisco.com/en/US/products/hw/routers/ps274/products_relevant_interfaces_and_modules.html
You might need to revise you're IOS, especially to support the ATM modules. Older IOS images (12.1 and 12.2) should fit within your current RAM/FLASH. 12.3 needs 32 MB flash.
Jon's is also correct, the 36xx series is also slower than many of the newer ISRs, but they do offer sufficient performance to drive the ATM links you're likely to connect to them.
As Jon, I too would suggest looking into the newer ISRs, for instance even the 2801 is a bit faster than a 3640 and supports the latest IOS. Investigate whether any trade-in allowance might be obtained.
Paolo Bevilacqua Thu, 04/10/2008 - 05:44
Hi Joseph, Jon hasn't jumped yet in this tread, or you able to see thing that I don't :)
Joseph W. Doherty Thu, 04/10/2008 - 08:37
Oops! Sorry Paolo, all the references should have been to you, but likely Jon would agree with your recommendation too. ;)
