Configure 7204VXR for VoIP Service
Apr 9th, 2008
Hi All,
We have intranet w/c is connected with two 7204VXR router. Just wanna ask what should i need in order to configure our intranet data connectivity for voip service with Avaya Definity PBX & how will i configure it.
>I have one DS1 card for Avaya definity
>a Multichannel T1/Pri
>a PA-VXC card
>T1 intranet Data Connection
Need your expertise on this.
Cliff
Paolo Bevilacqua Thu, 04/10/2008 - 00:32
Hi, if you never did VoIP before, I suggest you hire someone experienced, because it can take a long time and become frustrating when you try to do that alone.
This said, if you want to see some configuration examples, search CCO "definity integration".
