IPcom and QoS
Apr 9th, 2008
hello,
I use Ipcom 2.1.2.0 on Win XP SP2.
With wireshark, I can see the DSCP=46 for the RTP packets directly on
my computer.
when I capture the same traffic on a simple hub with another
wireshark I can see
DSCP=46.
About a minute after starting the communication, my wireshark, located
on my hub, indicates that my packets are no longer tagged at 46 but at
0.
Obviously, the hub is connected to my lan and is only used to capture.
Is anyone aware of that issue?
Thank you for your help on that matter
Ben
