VPN Concentrator 3000 Rel. 4.7.2.0 - NAC Issue
air2webinc
NAC policy keeps a client from connecting when it is not even enabled in the Base Group policy. Is this a known bug?
I get the following in the log:
55281 04/10/2008 02:59:59.890 SEV=4 NAC/27 RPT=181 NAC is disabled for peer - PUB_IP:76.111.36.xxx, PRV_IP:192.168.xxx.xxx
(IP Address modified for obvious reasons)
Any information someone can provide on this issue will be appreciated.
Thanks in advance!
owillins
Level 6
Level 6
This message does not refers that NAC is enabled on the concentrator. NAC is enabled at the group, if not enabled at the group it's as disabled as it can be - you can't shut off this message untill you remove the event from the logging configuration.
