VPN Problem
Apr 10th, 2008
Hi Guys,
We are trying to establish a VPN connection between 2 ASAs. When we generate the interesting traffic and run the sh crpto isakmp sa command we get the following output. Please see the attachment.
Please tell me what does State : MM_WAIT_MSG2 indicate?
andrew.prince@m... Thu, 04/10/2008 - 00:55
  • Green, 3000 points or more
1) Check your pre-shared key is the same both ends.
2) Check you are using the a isakmp/ipsec transform set that is available at both ends.
HTH.
