HREAP in this case?
Apr 10th, 2008
Hello.
We have a remote office that have two parts/rooms. First room has router, switch and some employees PCs second room has remaining PCs ,printers and switch of course. Only way how to connect these rooms was through wirelless. So we have now AP in each room.
Is there any possibility to manage them by our wlc? AP in first room has to do local switching so maybe to use HREAP. But I don't know how in this case.
Can you help?
David
David,
Both the AP's can be managed by your WLC, you need to tell the AP's about the WLC. Normally you would prime them.
However you need to convert them from autonomous (running IOS) to LWAPP, this can only be done locally to the AP's and they need to be taking out of production.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_qanda_item09186a00806a4da3.shtml
Then you would need to tell them about the WLC - priming. This would mean you would have to take the AP's to the same layer 2 LAN as the WLC....or you can do it via DNS or DHCP.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008069da69.shtml
HTH.
davidkares Thu, 04/10/2008 - 04:14
Thank you Andrew for your response. I know that by converting AP in first room to LAP (HREAP)it will be manageable by wlc and will be able to do local switching but I am not sure what about the AP in second room. The second room is accesible only by wirelles connection between these APs. My question is: Is it possible to make first AP as LAP (HREAP) and still be connected with second AP/LAP?
davidkares Fri, 04/11/2008 - 04:19
Thank you both for your help. I will use your advices to solve this problem. :-)
Scott Fella Thu, 04/10/2008 - 04:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
It is possible to manage thoses ap's on your wlc. YOu can either use local or h-reap mode, but just make sure of the minimum requirements for having ap's in either mode connect through the WAN. H-REAP would be the way to go if your ap's are currently autonomous. You still have to convert the ap's, but you will keep the same vlan info and ssid mapping.
Here is a thread that might help:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=Getting%20Started%20with%20Wireless&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc015f3/15#selected_message
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
