NAT + HSRP or GLBP + FTP inside Servers
Apr 10th, 2008
Hello Guys I need a Litle help, I have 3 days testing this and I Isolate a Problem which I dont understand.
I ahve setup 2 Routers C2600 with IOS 12.4(8) also try 12.4(17) both with same problem!.
Using SNAT FTP go slow as hell!
Config is very simple:
ROUTER A
interface FastEthernet0/0
ip address x.x.x.3 255.255.255.0
ip nat inside
duplex auto
speed auto
glbp 10 ip x.x.x.1
interface FastEthernet0/1
bandwidth 4000
ip address xx.xx.xx.xx 255.255.255.224
ip nat outside
duplex auto
speed auto
router eigrp 100
redistribute static
passive-interface FastEthernet0/1
network 192.168.9.0
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.129 !default gateway on isp
ip http server
ip http authentication local
ip nat stateful id 1
primary xx.xx.xx.3
peer xx.xx.xx.2
mapping id 10
ip nat pool ISP xx.xx.xx.130 xx.xx.xx.130 netmask 255.255.255.224
ip nat inside source list 110 pool ISP overload mapping-ID 10
ip nat inside source static tcp xx.xx.x.240 21 xx.xx.xx.140 21 mapping-id 10
access-list 110 deny ip 192.168.9.0 0.0.0.255 10.132.0.0 0.0.255.255
access-list 110 deny ip 192.168.9.0 0.0.0.255 10.136.0.0 0.0.255.255
access-list 110 deny ip 192.168.9.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 110 deny ip 192.168.9.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 permit ip 192.168.9.0 0.0.0.255 any
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
end
ROUTER B
ip address x.x.x.2 255.255.255.0
ip nat inside
duplex auto
speed auto
glbp 10 ip x.x.x.1
bandwidth 4000
ip nat outside
duplex auto
speed auto
router eigrp 100
redistribute static
network 192.168.9.0
auto-summary
ip classless
ip http server
BACKUP xx.xx.xx.2
peer xx.xx.xx.3
mapping id 10
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
If I disable Snat the FTP go very fast
when i enable it it go slow.. I have debug cached missed none, drops, none
looks like everythign have to do with snat on or off.. I needed ON to share nat tables and use aymetric traffict in ALG
PLEASY ANY HELP!? WHY SNAT MAKE MY FTP SLOW? the rest of trafic is fine with snat ON, email, remote desktop, pop3, web, 443, etc wherever I config for internal server work fine excep for FTP.
Also looks like TFTP got affected too.
I downgrade the routers to 12.3-5a and worked.. but i need some new commands from 12.4.
Many thanks
Raul
Overall Rating: 5 (1 ratings)
RaulMorales Thu, 04/10/2008 - 23:56
Ok nevermind I found the Solution, on IOS 12.4 I disable asymmetric Queuing using the command as queueing disable
So I am using GLBP for routing, and HSRP sor SNAT(because SNAT on HSRP mode allow you to disabe asymmetric Queuing) and now FTP is working fast.
Raul
