"Universal" Voice IOS
Gents,
I've got 2821 router running 12.4(9)T C2800NM-ADVIPSERVICESK9-M.
Wish it could support H.323, MGCP, SRST, CUCME, CUUE & GK based on single IOS.
Q:
1. Is this possible ?
- If no, what subsets of these Great-SIX can coexist ? Based on what IOSes ?
- If yes, what the IOS is ?
If there isn't possibility to answer unambiguously, please, explain the best methods
of determining such a combos ? Would it be only Feature Navigator ? Anything else ?
Thank you.
yes, in the past GK was incorporated in different images than now in 12.4.
I didn't remembered that GK is yet a different image from ip-to-ip gw, as you noticed.
5 Replies 5
paolo bevilacqua
Hi, GK requires ip-to-ip gw images, that is the filenames that ends in _isv. All the rest is in all voice images.
Paolo, thank you.
But does your answer mean, that if I upgrade to _isv image (by the way,
how is this de-abbreviated ?) I will have all abovementioned functionalities
including gatekeeper ?
Can you also recommend up-to-date IOS_isv version ?
And something else. Please advice what for _isv IOS is needed else along with gk ?
Thanks so much.
It really depends on which features you want. If not the very latest, 12.4(3j) is considered stable. I don't know what _ivs means, but I think you need that for GK.
Paolo,
I've been looking through IOSes feature sets and noticed
there are to different sets:
INT VOICE/VIDEO, IPIP GW, TDMIP GW
INT VOICE/VIDEO GK, IPIP GW, TDMIP GW
Even do not want to interpret these, but it seems that GK
MUST BE BASED on ip2ip images. Let it be.
On the other hand, I worked in organazation several years ago
that had implemented its GK on c2600-ix-mz.123-1a image. You
might not beleive, but it's has been working since that days :)
What do you think all about these, Paolo ?
Another opinions, guys ?
Thank you.
