Too Many Hops on ironport c350
Apr 10th, 2008
Hi Guys,
Can someone advise me on what these error message means on ironport ?What was the cause?
Final-Recipient: rfc822;validuser1@domain.com
Action: failed
Status: 5.0.0 (permanent failure)
Remote-MTA: dns; [ironport's ip address]
Diagnostic-Code: smtp; 5.1.0 - Unknown address error 554-'Too many hops' (delivery attempts: 0)
Reporting-MTA: dns; ironport.example.com.
thank you so much
Donald Nash Thu, 04/10/2008 - 02:43
"Too many hops" means just that: the message has passed through too many mail servers on its way to its destination, and has been bounced to prevent a potential mail loop. This may be due to a mail loop, or it may have other causes. The only way to find out is to analyze the Received: headers of the message.
Erich_ironport Thu, 04/10/2008 - 15:16
By default the IronPort "Hop Limit" is 100 hops, so as Don pointed out this is most likely a looping issue.
FYI - Exchange 2000 & 2003 have much lower hop limits and can sometimes trigger in non-looping situations. I believe the Exchange limits were 20 and 30 respectfully based on version.
Basically a "Hop Limit" is an anti-looping error trigger based on counting how many "Recieved:" headers are in the message.
Erich
angfeglandagan Fri, 04/11/2008 - 04:10
Postpix is configured to have a load balancing setup.
for example:
virtual ip: 192.168.1.5
physical ip: 192.168.1.7
192.168.1.8
public ip : isp1 = 11x.111.65.xx
isp2 = 202.xx.195.xx
I already configured the firewall rules to point to the ironport all smtp traffic.
then ironport will forward it to POSTPIX.
On the postpix..i configured to relay to Ironport.
I added an mx record for the ironport as the primary mx then the mail server as the secondary.
mx record config
10 - ironport
20 - mailserver
regards,
capt. winters
