IPM - Purge settings
Answered Question
Apr 10th, 2008
Hi, could somebody explain the purge settings to me. What exactly does it do? and to where does he purge it?
thanks
Correct Answer by Joe Clarke about 9 years 2 months ago
The IPM purge ages collector data out of the IPM database.
IPM stores report data in four time increments: hourly, daily, weekly, monthly. The shorter the reporting interval, the more data is generated, the lower you want to set your purge frequency. For example, hourly data is captured every hour. Depending on the number of collectors, hourly data can take up a lot of space in your database. Therefore, it is recommended you purge old hourly data every month.
Data is rolled up from the realtime data into the historical hourly, daily, weekly, monthly data until it is eventually aged out of the database.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Thu, 04/10/2008 - 09:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
