Integrate Avaya Definity with 7204VXR
Apr 10th, 2008
Hi All,
Just wanna ask how will i integrate a 7204VXR router with Avaya Definity PBX?
I just wanna use my T1 data connection for VoIP service to cater other calls from our Avaya definity.
How should i configure it?
Cliff
Rajesh Revuru Thu, 04/10/2008 - 04:38
  • Silver, 250 points or more
Hey Cliff:
Yes T1 interfaces would suffice.
I found a document which explains connecting two Avaya PBX using cisco IOS 3745 gateway, probably you could use this to get an understanding
Also if you have any future problem post your questios in IP telephony forum instead contact center
