CCM4.2 Intergration with Nortel Meridian Option 11
Apr 10th, 2008
  • Cisco Designated VIP,
    2017 IP Telephony
Guys,
Please I need assistance with this setup.
We have a 2811 that we are trying to configure as an MGCP gateway to interface a Cisco CCM into our Nortel Meridian PBX
Currently the E1 interface remains down, and in an alarm state
I will appreciate if ther is any documentation to use for this particular Nortel PBX for integration with CCM 4.2 using MGCP gateway..
VG: Cisco 2821, running IOS : c2800nm-advipservicesk9-mz.124-4.T2.bin
CCM ver 4.2
Attached is the sh run on the router...
At the moment the e1
Rob Huffman Thu, 04/10/2008 - 05:47
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Deji,
We tested using the following protocols, ESS5,NI2 and D100 (DMS-100).
The only one that has ever worked properly for us was DMS-100! .
Here are some great docs (have a close look at the White Paper);
Cisco Unified CallManager
Case Study: Nortel 61C PBX to Cisco IP Telephony Migration
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_white_paper09186a00801115e0.shtml
Nortel Meridian PBX and Cisco CallManager Integration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008011888c.shtml
Hope this helps!
Rob
cesar.fiestas Sat, 04/12/2008 - 12:42
How about any docs in how to integrate a 2821 with a nortel 11c. In this case the 2821 will emulate network for the nortel.meaning that when nortel phones dial out to the pstn..they will go out to the pstn via a pri in the same 2821...also when an inbound call from the pstn needs to be routed to a nortel user, the did will come from the same pri at the 2821. Any configs will be greatly appreciated.
ReadersUK Sun, 04/13/2008 - 02:26
You mentioned E1 so i assume you are in europe, i have this setup with CCME working. The router config may help i at least know the basics here are correct.Ill also attach the pinouts for a cable to a dual PRI card.
BTW the T203 timer was crucial to getting the circuit up and running.
interface Serial0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
isdn T203 30000
isdn negotiate-bchan
isdn outgoing ie display
isdn outgoing ie user-user
no cdp enable
regards
colin
